Might have to get someone to help me do that !!!!!!Lam46 wrote:LOL..you might be the first to read them Toddy..by all accounts..Toddy wrote:Full Fitting instrutions
Here's a new MBD speedo in Mouses new headset.
- Toddy
- Main scooter: Lambretta Series 1
Bilko
- Main scooter: LI150
Got mine.
Thought the instructions were excessive.......until I realised 99% of the paperwork was catalogues of the new stocks MBD are doing.
I read the instructions and read them again to make sure, but the rest of you getting one shouldn't have a problem. It does make sense and isn't complicated at all.
I was easy to set up when I connected it to the battery (off the Lambretta)
I like the look and the fitting wasn't hard at all.
Very happy. Thanks MBD
I received mine yesterday. I read the instructions and attached a battery as suggested to set it up.
The settings were easy to do i.e. tyre circumference, time, spark amount etc
However, when I waved the magnet in front of the sensor the mph doesn't change from 0.
Will this only work when wired correctly to the headset, I used a 9 volt battery for testing, this did light the speedo up but I'm wondering if it needs the 12v for the speedo bit to work correctly.
Has anyone tried this or can anyone try this, I don't want to put a faulty speedo in just to have to take it out again.
Has anyone got any pictures of the sensor connected on the front wheel with the magnet?
Bit of an update.
On further testing you need 12 volts for the speedo sensor to work, a 9v battery lights the speedo up but doesn't have enough oomph for the sensor to work.
Also the magnet's south pole has to face the sensor.
Still struggling to see how the bracket attaches without hitting the hub or getting the sensor close enough to a magnet glued on the hub.
Any pictures anyone?
Cheers.
Cheers.
- Toddy
The Bracket attaches to the Front wheel Spindle nut and sits inward towards the Hub like the vapor tech fixing , be careful that it clears your Valve when turning the wheel .KCB wrote:Bit of an update.
Cheers.
- Toddy
Keep us updated mate wont get mine fitted for a while as i have the engine out of mine for a winter rebuildBilko wrote:Hello toddy. Fitted, but not running. That's another story altogether......
