Mag housing damage / Up gearing
djh66
Main scooter: 150 special
1. In my clumsyness to get the mag bearings out, i've damaged the inside lip of the housing :cry: Is it still OK to use?
Uploaded with ImageShack.us
2. What will, changing my front sprocket (150 special, ali 185 kit) from a 15 to a 16 give me, in terms pof performance?
Cheers
Dave
Bring Me Sunshine COYH
joespeed
yes it will be ok to use,leave the gearing as it is and try it!
regards
joe
djh66
Thanks Joe, that's a relief. I'll leave it as is, for time being, but what would it do if I changed it to a 16 tooth?
Skar
djh66 wrote:but what would it do if I changed it to a 16 tooth?
In theory, give you a higher top speed, in reality it likely won't pull it or will struggle to pull it, unless you have done other mods? Better to stick with the 15 or at least give the 15 a try...
WINTERMODEL150
Hi the mag housing will be fine to use as its the shoulder that the seal sits up against,just check that its not cracked at all around that area,i've used a few like this before with no problems.
Regards Dean.
    Users browsing this forum: Google [Bot] and 29 guests
