Where to buy pwk idle jets?
I would normally use MBD for my parts but alas they are still out of stock. Where else can I buy idle jets for a PWK 24mm carb?
good service and website here also, genuine keihin also....http://www.splatshop.co.uk/performance- ... pares.html
Honeymonster
Don't know if your carb uses the same pilot jets as the 30mm but if they do then this is very good value from SCC,
http://www.scooter-center.com/scoweb/pa ... T_VERGASER
Thanks for your suggestions
