how to make a DL 125 faster
1960split
these may be stupid questions
i have a DL125 and its top speed only seems to be 47 mph(GPS).
everything is as standard will any of the following achieve a better top speed and cruising speed as the acceleration is ok
1) fitting a 42mm AF clubman exhaust
2) fitting a bigger carburettor
3) changing the sprockets to change the gearing
any help with the pro's and cons of these changes
thanks for any help
not a lot ....do you have to stick to 125?
fairspares
all of your suggestions would work but the barrel would need at least a slight amount of tuning and the amount of tuning will determine what size carb etc you could use, tuning is opening the ports to get more fuel/air in and exhaust gases out , it still wont increase the top speed that much on a 125 , you would be much better off fitting a 175 kit or mugello 186 with at least a 22mm carb and upgear front sprocket ,this will give you around 60 + mph, but it all comes down to how much you want to spend .
Wayne Miller
1960split wrote:these may be stupid questions
thanks for any help
How fast do you want to go? answer that and then the lads will tell you how to get there :-)
Stay tuned..............
Definitely DON'T do that without any other mods.
1960split
thanks for the replies
as for how fast i want to go
i want to get it sorted so i can ride at about 55MPH to keep up with modern traffic
i dont want to mess with it too much as it starts 2nd kick everytime and runs nice just seems to run out of steam in 4th gear
is it worth checking the jetting to see if this is correct
i was told it had a 150 top end put on it but cant confirm this
thanks for your help
storkfoot
I used to have a 125 Special which has the same gearbox as you. When I bought it, it had a GP150 cylinder on it. It didn't like it, it just revved it's nuts off in 4th. So, if yours revs high at full throttle but doesn't transmit the power to the road, this may be your problem.
If it just runs out of steam in 4th, rather than rev, then you may just be expecting too much. The 125 Special/ GP 125 set up was meant to be a quick "about town" scoot and was geared as such. It wasn't a scoot you could stick on a dual carriageway at 55 ;)
teamsequipe
RT 190
30mm PHBH
Remote Filter
GP200 sprockets
Decent 58mm Crank
Ron Moss Avanti exhaust
Cruise all day at 55 with no effort, up to 70+ for quick getaways
Ran a very similar setup last year, very reliable (after an exhaust change) and smooth to ride, lovely !
soosh
Total cost?
ricalnic
Main scooter: Lambretta GP Monza 225
maybe you could look at what Kelly has done with his 125 Supertune
