36 volt lambretta!!!
minotaur
i have been helping a mate with his lammy, mugello 220 , with variotronic, we now have it running ok and so turned our attention to the lighting with our trusty voltmeter at hand.
variotronic was wired as per instructions and on checking voltage at head set we are getting 24v on tickover rising to 36v when increasing the revs, on some cables, we did not have time to mess about and will investigate further during the week,
has anyone seen this before???, its on an Li150 with cut out switch, engine sparks fine , cut out works ok
sounds like the regulator isn't doing it's thing...
minotaur
that's what i thought, but it is all new, any one else had a faulty variotronic regulator? which would be the best way to check,? i have a good voltmeter and some regulators from other lammys.....
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
Are you checking it on the AC or DC range on the multimeter?
minotaur
started on ac , 36v , then he changed to dc on meter to just see what happened and got the same reading?
ForemanBob
Main scooter: GP RT230
What terminals are you taking the measurement from...
Could be a problem with the earth that you are measuring across.... Try sticking the black probe from the meter onto the engine casing....
minotaur
was using the headset bare metal as earth, thought this would be decent enough.
firekdp
If it's wired correctly, then either the reg is no good or the earth connection on it is poor.
minotaur
thanks firekdp, i was hoping you'd see this,
red ghost
Main scooter: lambretta gp150
Varitronic.... no 'o' except for the 'tron' part. Wonder what the new movie is like.. cool.. hopefully
