What's the trick?
red ghost
Main scooter: lambretta gp150
What's the trick for keeping off-set frame cones align?
cheers
Loctite ;-)
Hold in place with small grub screw thru frame in line with gap in cone. It's best if you put a divot in cone as well
AUSSIE
do you mean allowing the grub screw to locate into the slot in the cone? wont this stop the slot closing to pinch tight on the mounting rod?
I'm interested because I am having clearence problems on my TS
red ghost
But do they close down?
Stampede
Main scooter: SX200
LTH has slotted ones together with a special bolt - it´s adjustable from the outside!
Do this after you have tightened it up
camel
silly cone!!!!!!!!!!!!
