side stands
now I have cut my rear runners down, the oe centre stand looks a bit messy up, and bangs against the lip I made on the rear of the runners.
So, i was thinking about fitting a sidestand.
Probably get a motorbike one and make it fit onto the front LH frame strut.
what needs strengthening to do this ? I was thinking I'll probably weld whatever the stand pivots on onto the strut, then add some metal up to the centre tube and weld it there too ?
any pics of underneath with side stands fitted would be welcome.
any other pros or cons of people's experiences of using a sidestand ??
thanks
Thinking about it Byron, you won't need too much strengthening as there isn't that much weight on a side stand, it's not taking the full weight of the scoot like the center one does.
It will be a pain in the arse changeing either of the wheels though :?
coaster wrote:It will be a pain in the arse changing either of the wheels though :?
got a paddock stand for that :D
matthew
Hi Byron,
You're going to have to strengthen the point where the floor strut meets the frame tube. I've got sidestands on two lammies and both have had a plate cut and welded in to offer support to the floor strut. I learned the hard way when my Custom GP, fully loaded up with rally gear for Holiday in Holland ended up on it's side p1551ing out fuel at the Eurotunnel terminal a few years ago when the floor strut parted company with the frame tube! :oops: :x
cheers Matthew, that's what I was thinking
your experience sounds like one to avoid
is it enough to just strengthen the join, or is there a need to have a plate going as far as the end of the strut where the force will be ? I may well do that, in a typically over-engineered english style
Also what i always do ,when fitting a side stand..........is to weld in a tube between front and rear struts...........this helps spread the load /stress.
sean brady scooters wrote:Also what i always do ,when fitting a side stand..........is to weld in a tube between front and rear struts...........this helps spread the load /stress.
that's a good idea. thanks :D
    Users browsing this forum: Google [Bot] and 7 guests
