damper stud dimentions
red ghost
Main scooter: lambretta gp150
shocky wrote:this pic shows the type that push the damper out
in order to get the damper to run true from the side and the front i would have had to pack the top mount out by 6mm :shock:
Finally, someone who can use a camera for close up work!
Thank-you sir!
desi
Shocky, have just fitted the links I got off you a while ago and have to say everything squares off perfectly, thanks!
    Users browsing this forum: Semrush [Bot] and 11 guests
