Exhaust end/tip missing
westburyst
Hello,
The end of my exhaust is missing, would this have a negative effect on the performance/fuel efficiency of my GP200. It was like this when I got the scoot so not sure if it is running normal or abnormal. Seems to run fine. :roll:
I am thinking of attaching something suitable, as similar as possible in length and cylinder diameter as original - is it worth doing this? Would it be good or bad for performance/fuel efficiency etc??
Attached shows the highlighted in red area is missing.
Cheers
SIL GP200 92'
I've lost count how much I've spent.
storkfoot
The original Lynx exhaust was like that. Have you got a picture?
westburyst
I'll take a picture and post
Thanks
SIL GP200 92'
westburyst
SIL GP200 92'
westburyst
No takers :shock:
SIL GP200 92'
storkfoot
It's not a Lynx one. I'd have to say if it was my scoot, I'd at least try a standard 200 exhaust to compare the two. I wouldn't bother trying to fix an end pipe.
Have you asked the person you bought it off about the background to this exhaust?
It's something I've seen a lot of on Maltese scooters for some reason and knowing what they are like over there I'd suspect they think it gives it a boost for no extra money. Because they won't pay money for anything if they can help it. :D Whether it does or not I don't know. I'd suspect not and that it might make a standard engine feel a bit gutless.
joey
...bin it buy a ancillotti or af clubman.....its broke off probably because its not been secured to crankcase....
westburyst wrote:Image
wtf is that thing ....pidgeon spike??
westburyst
:anbrgin; Lol yep pigeon spike. I live in a block of apartments and these damn things keep falling off from the window ledges/roof edge etc...
yep i will be replacing the exhaust.
Cheers
SIL GP200 92'
    Users browsing this forum: No registered users and 81 guests
