Hi.
Can you tell me the size of a RamAir filter to fit into a standard dellorto 22 air hose?
http://www.scooter-center.com/scoweb/pa ... rds=ramair
Thanks!
RamAir filter size?
- ArKaTxU
- Dealer
- Main scooter: TV175 64-Jet200 68-Jet200 82
Then I must see how much is the outer diameter of the original rubber hose and buy proper one.storkfoot wrote:Have a look at this site, mate:
http://ramair-filters.com/motorbike/fra ... rbike.html
Thanks!
- corrado
- Dealer
- Main scooter: Lambretta GP
I found the best way of fitting a ram air to a GP elbow was to use a small length of plastic plumbers pipe, insert half into elbow and half into ram air and use a jubilee clip on both. The ram air size will be the same size as the outside diameter of the plastic pipe. I've done one, when I find it I'll post the size.
- ArKaTxU
- Dealer
Perfect Martin!corrado wrote:I found the best way of fitting a ram air to a GP elbow was to use a small length of plastic plumbers pipe, insert half into elbow and half into ram air and use a jubilee clip on both. The ram air size will be the same size as the outside diameter of the plastic pipe. I've done one, when I find it I'll post the size.
the pipe? 32mm and 44mm of top of my headArKaTxU wrote:Perfect Martin!corrado wrote:I found the best way of fitting a ram air to a GP elbow was to use a small length of plastic plumbers pipe, insert half into elbow and half into ram air and use a jubilee clip on both. The ram air size will be the same size as the outside diameter of the plastic pipe. I've done one, when I find it I'll post the size.
