Anyone else had this problem with sleeved stubs....any advice welcome...
Ta
sef
Are these nuts slimmer in profile allowing me to get the socket over the nut and inside the side of the stub?eibargum wrote:If your problem as i read it is theres not enough room for a socket because of the closeness of the stub then while holding it in your hand or a vice flat off the side of the stub next to the hole with a powerfile or just a file untill you can get a socket on, had to do this on mine, the exhaust nuts off a Vespa GTS are also a good way to go.
Yes they are, you can get a socket on but they do have a flange on the bottom, which is not a bad thing, cant take the credit though as Martin at Chiselspeed put me onto themsydduckett wrote:Are these nuts slimmer in profile allowing me to get the socket over the nut and inside the side of the stub?eibargum wrote:If your problem as i read it is theres not enough room for a socket because of the closeness of the stub then while holding it in your hand or a vice flat off the side of the stub next to the hole with a powerfile or just a file untill you can get a socket on, had to do this on mine, the exhaust nuts off a Vespa GTS are also a good way to go.
Ta
