Franspeed stub question..
sydduckett
Got this stub for a Franspeed for my rb, its not a good fit and theres quite a bit of play. question i have is, are the 2 grooves in the stub for o-rings and if so where can you get them from? Also if i dont use them will silicone or similar do the job as theres quite a gap?
Ta
sef
ArKaTxU
Andy Francis have:
http://www.ekmpowershop12.com/ekmps/sho ... -336-p.asp
I want to know too if silicon or similar can do the job, because i have the same stub.
Now he have another stub:
http://www.ekmpowershop12.com/ekmps/sho ... 1610-p.asp
bazman
Think they done away with the stub that had the o rings as you had to replace them every time you took exhaust off.
sydduckett
What to do, what to do? Should really go for the stub but could just buy 4 rings as how often do i take the pipe off? Do you need 2 though, as there are 2 grooves? Also the one item on his site that doesnt have a buy button is yes you guessed it the stub... :x
Typical, will buzz him tomorrow.
Bilko
Main scooter: LI150
What size are these o-rings?
Bilko's Oily Blog
sydduckett
ended up buying the updated rb stub with a sleeve from Andy Francis.
Thanks for point me in the right directiom.... :D
Bilko
Main scooter: LI150
I was going to buy a batch from ebay. Just need the size
Bilko's Oily Blog
sydduckett
Bilko wrote:I was going to buy a batch from ebay. Just need the size
Not sure best to call Andy Francis as he makes the franspeed and sells them. I think they need to be heat proof though?
Bilko
Main scooter: LI150
Ah ok. Thanks
Bilko's Oily Blog
Bufficus
These O rings were rubbish from the start and have not improved. I use acetoxy clear silicon sealant every time I remove my exhausts even on proper slip joints. Never had a problem.
You shouldn't have to pay £20 for a new stub due to a design fault.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
