Brake Pedal Circlip Not Holding
Bilko
Main scooter: LI150
Thanks for the advice, except you red :p
I'll try for a broken tap extractor thingmie
Bilko's Oily Blog
Never mind mate,s**t happens.Is there enough tap left to weld a nut to it? even if there is only a small stub left you can MIG a nut on and with plenty of lube gently ease it out-hopefully ;)
Bilko
Main scooter: LI150
There's nowt but about a 1mm point.
Bilko's Oily Blog
Worth a try is 'nt it? Try an M4 nut for fit,you have nothing to lose.
Bilko
Main scooter: LI150
Yes of course.
I'll call a friend with a wee mig. I'm going to have to get one. Been meaning to for years
Bilko's Oily Blog
joey
....f... it fit a rear set brake bin leggies panels n cut back end off.....sorted....... :lol:
good luck sortin it out....'oh the joy of scootering'
Boo
Mig Welding a nut on to a broken tap will just brake off because taps are so brittle only thing you can do is replace pin with new or get a small piece off hack saw blade and go round the inside of cir-clip groove and try again with cir-clip i had same problem worked for me cir-clip stayed on 8-)
Lambrettas are for life!
red
Bilko wrote:Thanks for the advice, except you red :p
Always a pleasure mate :D
desi
I've also seen SS threaded (non-weld) brake pedal pivot pins. Cut off old pin and these simply tap in (locktiting threads). Can't for the life of me find the site I came across them on, but I remember thinking they looked like a cracking tidy fix. Perhaps someone else will know of them, if I manage to find I'll post link.
TheSeeker
Bilko wrote:Yes of course.
I got a small gasless mig in the summer second hand and can recommend them. With a bit of practice you can get a really good looking weld.
Light years ahead of arc/stick welding which I found was always very hit and miss with blobs and splatter all over the place.
Ben
