Brake Pedal Circlip Not Holding
Bilko
Main scooter: LI150
Having a b@5t@rd of a time trying to keep the circlip on the brake pedal mount.
It's clean, the groove is also cleaned out, but the circlip just won't hold when you press the pedal more than a few times.
It feels neat enough when the circlip is in, but I wonder if the mount is just worn. I've used different circlips that I've got with the same result.
Is there another option?
Bilko's Oily Blog
drill /tap out (thread) and put a bolt in
Had the same problem on my curryburner.. :D , as Ric says, I went the Jason Frost way and it worked a treat, dont know if the pics got blown off his photobucket site though..
herse mine
basiccally its all held in place by a grease nipple with a crossdrilled shaft ti enable the grease to come out and lubricate
yeah well i was gonna suggest that too......
storkfoot
If the bush in the pedal is worn out then when you press the pedal, it skews over and pushes the circlip out. I'd check that before I go any further if I were you ;)
Bilko
Main scooter: LI150
f@@king hell.
I don't know what I'm going to do. I certainly don't want to take the leggies & everytrhing off to drill the mount.
Bilko's Oily Blog
wack 63
Main scooter: '71 GP TS1
If the pin is not too worn a gear shaft bush in the pedal can help as the nylon ones wear quickly or are a loose fit new.I shim the pedal both sides as well as it seems to stop the pedal twisting.As for drilling you should be able to get in with a small battery or air drill without removing the legshields.Use a ratchet tap holder.
Bilko wrote:f@@king hell.
Smash it with a hammer and super glue then..................... :frog:
No..Im certain you will have to lift leggys Bilko, even if you get a long reach drill bit you still need the turn room for to tap it fella...
I've done it without removing the legshields, using a tap holder with a sliding rod handle...
