warm start issues
sparrow61
Main scooter: Li 125/175
having trouble with engine warm start, running with a jetex 22 mm carb settings being 45 pilot 50 choke and 123 main. She kicks over without choke on a cold start but gives trouble when kicking over when warm. :(
bristolmod
what CC? What state of tune etc?
Someone on here sugested a 1mm hole in the rubber inlet from the air filter - tried it at the lowest point and it seems to cure any warm start issues with a Jettex. Only drawback is the fuel which is normally spit back, being deposited on the inner floorboards
Scootering since 1968.
you could retro fit a tube as per the old type rubbers to direct drain below say fan cowl.
lockman69
Sounds to me , you have a problem with your choke not closing off.
you should really need the choke to start from cold....
other warm non-starting causes can be:
fuel filler cap blocked
plug gap
worn rings
something electrical breaking down
Knowledge
Warm starting issues with points ignition is often indicative of the condenser breaking down, but you don't give us enough info in your original post.
Is it points or electronic?
Martin
eibargum
lockman69 wrote:Sounds to me , you have a problem with your choke not closing off.
Agreed, thats the first and easy,st thing to check.
Ricko
Sounds to me that you have joined the club of many, self included in the past........the world of Lambretta's. :(
sparrow61
thanks lockman69 have checked the choke out today and found a small burr on the choke jet , this i have dressed. Have taken the lammy out for a run and everything seems better when kicking over on a warm start fingers crossed it stays like it. ;)
sparrow61 wrote:...everything seems better when kicking over on a warm start fingers crossed it stays like it. ;)
cool. a simple fix
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
