Disc pads
bristolmod
standard front disc on a TV175 S3.
Just had its MOT, and the tester told me the front brake was "just within spec"
Recommended that I look for some "abrasive EBC" pads if possible. Anyone know if there is such a thing, or any ideas as to how to improve a standard set up- don't want to go hydraulic.
Any suggestions Gents?
Scootering since 1968.
ArKaTxU
Sintered pads + reverse pull?
wack 63
Main scooter: '71 GP TS1
Try EBC FA 100 pads http://www.ebcbrakesdirect.com/bike/par ... 9&sec=Euro Seem to work fine although won't pull a stoppie with a cable set up :) Don't worry about the wrong pic on the site
rog60
Main scooter: Indian GP200
Just fitted Newfren sintered pads(bought from Glasgow Lambretta) to my remade inboard disc brake.Much,much better than the un-named brand previously fitted :)
J1MS
I fitted the same to my TV before the euro, there pretty good.
J1MS
Need better brakes on mine thinking of losing the standard look disc and fitting an outboard instead, nearly hit a car in the outside lane on the M62 going to the euro hadto cut back into the inside lane to avoid a crash brakes not good enough at speed, still on a standard cable not even reverse pulled.
Never seem to get time to do my own scooters.
joee
rog60 wrote:Just fitted Newfren sintered pads(bought from Glasgow Lambretta) to my remade inboard disc brake.Much,much better than the un-named brand previously fitted :)
is that the copper coloured ones? squeal like buggery..
Going to order a better disc and pads from al diablo...should have done it earlier
randall ate my dog!!
no one likes us we dont care
Arch_Stanton
Fitted a set of these a couple of years ago, very effective but only had to touch the lever and as mentioned they squealed, is there a cure for this?
rog60
No grey with metal dust impregnated, black lacquered. had to grind them down a few thou on outside edge to fit properly....don't squeal.. put copper slip on backs to prevent that :shock: :shock:
bristolmod
Thanks Gents- some good ideas here.
Going to try the sintered route first
    Users browsing this forum: Google [Bot], Majestic-12 [Bot], Semrush [Bot] and 4 guests
