quality clutch
carbon lammy
need a new clutch got a cam lam 5 plate at moment but slipping bad now.are reedspeed six plate any good? or any sugestions without speeding £400,cheers
Definetlyis 100 times better
Rich_T
Main scooter: Li Special
I'll have the first batch of low cost 7 plate clutches done by this Friday. This first batch work out at £260 or £220 if you can supply an exchange Aprilia unit.
This clutch unit is designed as a low cost 7 plate alternative and uses donor parts from Aprilia RS125 (clutch donors can be from either 122 or 123 engine models, but 122 is the most common). I plan to use them on my billet casing engines to keep the costs down but they could just as easily be used by racers with a packing plate or street applications with a packing plate and extended kick start.
Ten will be available in this first run.
red
carbon lammy wrote:need a new clutch got a cam lam 5 plate at moment but slipping bad now.are reedspeed six plate any good? or any sugestions without speeding £400,cheers
I've used a Readspeed 6 plate in my TS1 for the last 3 years with no problems at all-was also used in all 3 of my RB's
