Help fitting a 22 delly on a Standard TV175 III
Supereibar
Hello peeps, I need help with the setup of an original TV175 Series III with a 22mm dellorto. Any ideas for a setup? Would you use a standard 22mm for a GP200 just as is? Would you change the jetting? Pilot? Ideas?
Any help greatly appreciated.
I should have thought it would be pretty close with the standard jetting for a GP200. You might want to come down on the main jet perhaps. But the only thing to do is try it.
bristolmod
Jaime
I'm running 22mm on both my TV175's (albeit Jettex's)
I jet them as per GP200 (main jet 123) and they operate very well at that spec.
Chris
Scootering since 1968.
Supereibar
Thank you both. Top men!
    Users browsing this forum: Google [Bot], Semrush [Bot] and 14 guests
