fitting a franspeed rhaust help neededace ex
rps123
Trying to fit this franspeed race and as ive never seen one on or owned a jl can anyone let me know how the brackets are meant to be where the nylon washers go and best way to fit it, ive been messing with it over 2hrs and it doesnt seem to be right which ever way i do it, i wish it had a dummys guide to fitting sketch with it? Cheers in advance for anyone who can help
Bilko
Main scooter: LI150
Did you ever get this sorted?
I'm asking as I'm trying to fit my franspeed tourer and the endcan fitting point to side casing seems miles out.
I'll post a couple of pics shortly
Bilko's Oily Blog
Bilko
Main scooter: LI150
Here's my problem.
I bought a fixing bracket bought had to drill another fixing point on the higher point, but it's too far forward.
The picture doesn't show it very well, but not only is the rubber point too far forward in relation to the tail can bracket. It's too far away.
The exhaust body is almost touching the side casing. So it can't move any more closer.
I really don't know what to do. I can add my JL nylon bush to the tail can bracket, but it will be under strain. Would that hold?
Bilko's Oily Blog
ricalnic
Main scooter: Lambretta GP Monza 225
bilko, no pics to hand of mine tonight, but just a thought, is your bracket put together correctly at the front of the chaincase, being out a bit there would exagerate the space at the tail can. must say my Franspeed is probably the carlsberg of exhausts for fitting, absolutely cock on.
ArKaTxU
Bilko, i have the same problem with a RB20 and a Franspeed Tourer, and finally i put two small JL nylon bushes.
Diablo
This is going to sound really daft but bear with me. Have you pushed the can as far as it will go into the main body of the pipe.
I fitted one recently and the paint prevented this untill I gave it a realy hard shove and twist . This at least brought the hole as far forwards as the rubber bobbin.
Bilko
Main scooter: LI150
That's a good point Al, but I tried that also.
Bilko's Oily Blog
ArKaTxU
This is mine:
Bilko
Main scooter: LI150
Yes indeedy, that looks something like mine, but I have the 3 point fixing bracket from Andy Francis, which I had to drill a new fixing point.
I was worried that the gap was too big with the extra bush. Is yours ok?
Bilko's Oily Blog
ArKaTxU
Bilko wrote:Yes indeedy, that looks something like mine, but I have the 3 point fixing bracket from Andy Francis, which I had to drill a new fixing point.
Mine is ok.
    Users browsing this forum: Semrush [Bot] and 10 guests
