dodgy stator plates
Tosh
Well what can i say New bloody engine well now run in had top end tuned by our friends then the stators went faulty ,
1. at low rev`s
2. at high rev`s off another engine what ran ok.
now sean has put me a 3rd one on and all is ok at mo (its a lammy ;) ) now both give correct readings as stickys is their another way to check for these failures or not,and is there anybody in the lancs area coppull actually who could fix them.
Thanks Paul
What stator plates are they?
battlam
Main scooter: Lambretta gp
What flywheel is it? is there any chance it could be that or maybe the crank has twisted?
Tosh
Ta for the reply`s chaps the scoots running ok the stats are indian ones and the fly is as well all from my other engine
ratty
Main scooter: LI ser3 125 {TS1 230} 1963
my mate is having the same problem, will run fine then start missing, put a new stator on ran fine then played up again. have changed wiring loom and cdi but no different only option left now is ignition switch/headset wiring.
how much!!!
ratty wrote:my mate is having the same problem, will run fine then start missing, put a new stator on ran fine then played up again. have changed wiring loom and cdi but no different only option left now is ignition switch/headset wiring.
HT lead and cap?
