Toolbox Flywheel Holder
What options, apart from a chain, are there for a compact flywheel holder? I've seen one at Rich Presley, is it any good or are there other alternatives?
sure ive seen some with a two part handle that fits in standard tool boxes ,is this what you have seen allready?
RICSPEED wrote:sure ive seen some with a two part handle that fits in standard tool boxes ,is this what you have seen allready?
This one?
http://www.richpresley.co.uk/lambretta- ... -131-p.asp
Doesn't look too compact or lightweight to me :?
jimmers
it is what is says
i have one
although handle section that is seperate was too heavy for me
so replaced with some steel tube from work
shorter and slides over outside of stubby piece on main part
works well
didnt have it on me in spain just when i needed it too :roll:
soullad
Good job I saw you then fella ;) ;) Never forget how hungover David and Rob looked. Oh and the Tv that twisted its crank just pottering down past us...
Anyway Mikes got a point, I had to carry a magnetic tank bag full of tools / spares, and the flywheel holder is one of the biggest tools in the essential set so to speak.
Thanks for the input. My garage flywheel holder has a handle of steel box section, it might be an idea to cut it in half and fit a joining piece. I could then cut off the three prong side that I dont use and that should lighten it a bit too :idea:
joey
...vega chain is all you need ;)
soulsurfer wrote:What options, apart from a chain, are there for a compact flywheel holder?
joey wrote:...vega chain is all you need ;)
Big screw driver trapped in the fins and rammed in the housing..... :baddevil: ..hands up who hasnt done this at some point in there lives.. :D
Trouble with that one is that the prongs are flat so it slips off the flywheel too easily, the slots need lugs on them to lock into place.
