flast spot as rolling throttle off...?
lammysilver
Just run to the IOW and back, on a new SR kit, ace, no probs at all.
Only thing i have to remedy is a slight flat spot when rolling off from full to 3/4 throttle, more apparent when going fast in fourth.
Also when revving up it has a very slight splutter as you rev through from 3/4 to full throttle.
Im running a 28mm Del with a sr175 kit, 42mm clubman...
105 main, 50 pilot, av264, X7, 40 slide.
what clip is the needle on ?
lammysilver
second from top
