Speedo back-light
red ghost
Main scooter: lambretta gp150
I have this kind of speedo:
And I have this kind of bulb:
But still the lighting isn't all that fantastic, anyone have a suggestion?
leigh
What kind of bulb is that, did you get it from NASA.
Leigh
red ghost
They are pretty much the "yar-yar's" of LED technology, burn your retinars out with a single flash :shock: . But back to the problem, maybe the plastic back is too dense to pass light?
thoughts anyone?
leigh
Probably right about the density, personally i just make do wih a crappy speedo bulb as long as the head and tail are ok.
Leigh
P.S. sorry probably not the reply you was after.
well as led's tend to be directional the ones on the side wont light anything and it just leaves you with the one on the top :(
red ghost
I used the above type LED in a series 3 speedo and it worked great..
red ghost
And just to add, with the GP speedo and above LED, there is fantasic light comming thru where the odometer is just not thru where the speed is.
One idea I had, is to replace the needle for one made of a clear plastic with a red top (just look at any modern car) so that the clear plastic catches the light. A late model vw golf is a good example.
It will be twice as bright on a DC system over an AC system ;)
red ghost
True, I'm running 12V Varitronic with a battery.
    Users browsing this forum: Baidu [Spider] and 1 guest
