Small-end
Daggs
I'm stripping an engine for a friend. I've just found the conrod small end to be a bush! Has anyone encountered this before?
bristolmod
Andy
most pre S3 engines were indeed a bronze bush instead of a seperate small end.
Scootering since 1968.
Daggs
I didn't know that.
However this is a series 3 engine. The deeper i get in, the more bodges and damaged parts i find. I think this engine has spent some time in the far-east. It's owner is going to be a little upset i think! :(
bristolmod
I'm pretty sure that all S3 engines came with a seperate small end, so its not a "carry over" to the very early S3's from the S2's
Crank replaced in the dim and distant past with a S2 item?
Or, as you say a "VC Special"
Daggs
No i'm afarid there's a distinct smell of fried rice around this one.
Some of the bodges are just frightening...... :shock:
    Users browsing this forum: Amazon [Bot] and 1 guest
