carb rubber
sydduckett
anyone know where i can get hold of a stepped carb rubber for a 30m delly on a RB20, or does anyone have one to sell. alsowas told that VW ones fit perfectly but not sure what model or year?
Ta
sef
Fruitjuice
It's the carb rubbers from Volkswagen T1 and T2 vans, but mine and at least one other person I know using them had ours split in less than 500 miles from fitting. Luckily both times it caught in time before having engine damage. Don't know why they did but I'm not using them again...
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
10 inch Terror
Xbox live gamer tag: No.
sef, i have a quality rubber sat in my shed that i'll never use. I know one side will fit a 30mm Delly carb, if you post the dimensions of what you need i'll measure my one up if it's any good to you, you can have it. Cheers Pete.
Bufficus
Fruitjuice wrote:It's the carb rubbers from Volkswagen T1 and T2 vans, but mine and at least one other person I know using them had ours split in less than 500 miles from fitting. Luckily both times it caught in time before having engine damage. Don't know why they did but I'm not using them again...
The VW rubbers I had were far too flimsy for a heavy carb. I messed around with stepped rubbers for ages, but was never really happy with them. This was on a TS1. In the end I just bought the correct inlet for the job. And then changed to a bigger carb again :roll: I now have four inlets for a TS1 and three reed blocks. Why do I waste my money so?
Does anyone do a smaller inlet for the RB20 yet?
sydduckett
10 inch Terror wrote:sef, i have a quality rubber sat in my shed that i'll never use. I know one side will fit a 30mm Delly carb, if you post the dimensions of what you need i'll measure my one up if it's any good to you, you can have it. Cheers Pete.
Cheers for the offer but have now got one. Roll in IOF... :D
    Users browsing this forum: Google [Bot] and 9 guests
