rev counter = speed ?
wezly wrote:Soulsurfer, do you have a link to the online manual for the clutch? I need to know what metal the crownwheel is made from?
http://www.granturismo.pwp.blueyonder.c ... manual.pdf
10,500rpm in 4th on the road is damn impressive, what motor spec do you have to do that?
wezly
Thanks.
wlightning
I am sure you have seen my bike on the road and at custom shows. IT was put together by chalky & chiro (replay scooters) but a good friend of my
no helps look after it (Guy Topper). 240cc mug, welded casings, 62mm crank 115 rod, racetour piston,tunned by guy & chalky, granturismo clutch, pipe made by Guy,pacemaker box, and so on... WE are fitting new barrel to bike a muggy proto type not on shelves yet. and a new bike ignition with a smaller lighter fly wheel.
gadgetman
Hope you have plenty of air pressure in those tyres Carl at 90mph. Have you found out why your chain failed ?
