Front Hub Top Hat
lammy mark
Main scooter: Series 3 Special s type rep.
I am building a Spanish Series 2 at the minute. The front hub is causing me a bit of concern. Its a standard drum brake, and if I put the top hat on, the hub does not fit together right for some odd reason. With the top hat fitted, there is a bit of a gap between the two halves of the hub, and the brake does not engage right. Is the top hat essential ?
lammy mark
Sorted 8-) A spacer solved the problem :D
    Users browsing this forum: Google [Bot] and 19 guests
