p2 timing
skinhead63
Main scooter: px 225 ish
hi i am building on a vespa 225 can any one tell me which of the 2 marks on the casings is closest to 19 degrees thanks
joeythescooterboy
The "IT" mark is supposed to be 18 degrees but it's best to use a degree disc as the marks are intended as a guide only. The "A" mark is 23 degrees for a standard P2.
skinhead63
joeythescooterboy wrote:The "IT" mark is supposed to be 18 degrees but it's best to use a degree disc as the marks are intended as a guide only. The "A" mark is 23 degrees for a standard P2.
thanks for that will use a disc :D
    Users browsing this forum: No registered users and 59 guests
