Will this run
Jazzy
Lambretta barrel,
exhuast 180 degrees
inlet 130
transfers 117
what do ya recon.
jonny snatchsniffer
it will run, the inlet and transfers are a little low tho for the exhaust timing so it will be a bit peaky
fred
think 130 inlet must be a typo,sure it's not 150?
personally i'd prefer more transfer timing,but that's just me perhaps.
fred
Jazzy
a bit off the piston might help then :?:
ps this is for a straightliner
tarmac tickler
if you are going sprinting mate i would say those port timings are extremely conservative, even more conservative than maggy thatcher!!!
Jazzy
tarmac tickler wrote:if you are going sprinting mate i would say those port timings are extremely conservative, even more conservative than maggy thatcher!!!
can you point us in the direction of somthing a bit more Nick Clegg then
Special X
190 exhaust
130 Transfer
158 Inlet
Wouldn't be over the top for sprinting
tarmac tickler
an experimentl iron barrel going on the dyno at the run to the shires this weekend..
exhaust 202 :D
transfers 150 :D
inlet (forgot to measure it) :oops: :oops:
gear box gt200 46/15
will post results sunday
jonny snatchsniffer
Jazzy wrote:a bit off the piston might help then :?:
a bit off the piston will help but it would be better to work the inlet so it has more port time area
widen it and lower the inlet but leave a few mm so the piston skirt covers the port id also go with around 165 withe inlet
trouble is gonna be getting the transres up to about 130 ish
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
