AF Electronic Stator Kaput after only 12hrs
willwander
I recently bought a new AF Electronic kit with stator and lightened flywheel.
Stator has gone after only 12 hrs use, works fine until engine gets warm then produces an erratic spark.
I traced problem back by replacing everything behind plug until I reached stator.
Anyone else seen this?
standing mile: 118.6mph
dave wheeler
Hi Will
yeah i had the same problem,the hole where the wires emerge from the back of the stator is razor sharp and cut through the red and yellow wires, unfortunately it knackered the cdi, so you might want to check that too, and we all thought electronics were maintainance free!
regards
Dave
willwander
Yeah wires are fine. I replaced everything one at a time starting with plug and worked back.
Putting different stator on seemed to fix it.
It's fine until engine warms then fails to hold a spark at much over tick over.
Are these normal symptoms of a dodgy stator on the way out?
willwander
dave wheeler wrote:the hole where the wires emerge from the back of the stator is razor sharp
Dave
Wow, I see what you mean
petemaisey
It could be a "dry" solder joint. On the earth tag perhaps.
Pete
    Users browsing this forum: Semrush [Bot] and 16 guests
