gearing
runnin a imola 186,,with italian gp200 18 x 47,,was thinking of changing to 17 x 47 any advantages or disadvanteges..cheers steve
Knowledge
- Dealer
- Main scooter: GP
The standard GP200 pulls the 18/47 gearing well, and only makes 11.7bhp at the crank. I would hope that your Imola produces at least 11.7bhp at the back wheel, so it should pull the 18/47 gearing without a problem. Of course, I have over simplified this, as the torque has some bearing on the way it pulls the gears, but as long as your scooter continues to accelerate in 4th with 18/47, then it is not over-geared.
By all means try the 17/47 and see if you prefer the improved acceleration, though do try a bit of motorway work as well in case you find it is revving its nuts off at 60mph.
Martin
mine neither, only really just coped with 5.2 final ratio, and ended up at 5.4, which isn't far off 17 x 47 on a GP2 box anyway.
thanks fella,s 17 tooth it is then,, all the best steve,,
im using a scoot rs pipe corrado,, cheers steve
