agusto unit
sjc
want to fit a unit for a imola 186 engine,,wot one would you go for,,many thanks steve... :roll:
6000..... Actually, if I were to buy another, I'd check out the Chiselspeed one.
10 inch Terror
Xbox live gamer tag: No.
soulsurfer wrote:6000..... Actually, if I were to buy another, I'd check out the Chiselspeed one.
I'm always hearing good things about Chiselspeed, but can never use their website. Is there a new one?
10 inch Terror wrote:I'm always hearing good things about Chiselspeed, but can never use their website. Is there a new one
Funnily enough yes coming very soon, this was a reply from chisel to me and Eden the other day when we asked the same..
i'm afraid that for the next week or two until the new shopping site is up and running the only thing thats visible is the old site which i dont have any control over due to the git that built it having done a runner with the management log on etc.so i haven't been able to get on it for 2 years!so it wont be much longer and we'll be online properly for the first time.Martin
same here
willwander
There's always the phone.
ChiselSpeed = 0113 2811052
There's nowt better than talking to someone that knows what they are doing.
standing mile: 118.6mph
wlightning
You could always ask Chalky at replay scooters I have introduced a few of you yorkshire lads to him and they have all said the same what a great gen guy
so helpful not a rip off merchant like some ;) chisselspeed version ok but to progamable and if you not too sure what you doing could blow your engin up.
mawso
I've got the Chiselspeed unit...pretty straight forward really. Lots of settings yes, but they're clearly laid out and explained on accompanying instruction sheet as to which setting corresponds with which version of the Augusto and also what the other settings give. If you don't want to to tinker and are not confident to change settings straight away, then set it to which Augusto setting you want and leave it at that initially. You can always play with settings at a later stage.
Remove the cover and then just switch it to whatever range you want. Ideal if you're riding to a rally with luggage set it accordingly then when you want a quick razz around the streets you can set it again...I like it anyway!
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 5 guests
