Engine building
LI150
Main scooter: Series 2 LI150
Dont know if this is what I am intending to do just a thought really but what could I use on my current engine if I built an engine using a 200 crankcase using mine as a donor.
My engine is a series 2 li150. It does have a mec gp crank and electronic ignition so can use these but what else and what would I need to buy.. :?
Diablo
Gearbox,sprokets and chain,clutch
bearings and seals and gasket set
LI150
Diablo wrote:Gearbox,sprokets and chain,clutch
I take it you meen these are ok to use.. :D
Diablo
Sure. Standard LI150 with 15/46 sprockets has a final drive of 5.2 same as GP200. If they are in good nick no reason why you cant use them.
The clutch wil need new corks and springs but everything else is useable. Check you haven't got the sprocket with springs in which thinking about it you may well have.
    Users browsing this forum: Google [Bot] and 24 guests
