vespa 166
wayne the mod
Main scooter: vespa 166/lambretta ts1
hi guys ime having a problem with my 166 i can do 70mph in spurts but when i sit at 55mph after about 5 miles it just loses all power and cuts out as anyone got a answer because its doing my head in thanks
acko
Sounds like you are heat siezing.
Could be incorrect jetting,timing,air leak,etc.
In my opinion Malossi kits are crap and a bitch to get set up.
Never got one running right.
Good luck with it. :mrgreen:
Better to be someone for a day than no-one for a lifetime
wayne the mod
ive had it apart there was only one seize and that was due to my autolube packing up on me the timings ok and the plugs ok it maybe runs alittle rich and some times when it goes it will i can pull over rev it and off it goes like nothings happened but i will take your advice in and check everything you said and try and find a solution cheers acko
jonny snatchsniffer
fuel starvation
ducksta
have you changed fuel line recently, sounds like fuel
