SPARK MAGNIFIER!!!
Dazza
All epoxied up and ready to go:
Started ok but won't try a run till tomorrow night....
Dazza
Well, I made cleethorpes and back with it on, it did seem slightly crisper, I think I may have used slightly less fuel than normal as well, worth fitting it? Jury is still out on that one I Think
minotaur
........well ordered one last week, arrived today, took 2 mins to fit and my gp with casa 185 does feel crispier and a little more lively up to 1/4 throttle and a tad smoother after that.
it makes the scoot a little better to ride
soullad
really need a dyno run before and after, to compare, esp the A/F ratio .... Sean, Dan?
soullad wrote:really need a dyno run before and after, to compare, esp the A/F ratio .... Sean, Dan?
Someone send me one and it will be done.
yes looking forward to testing those out... :D
Dazza
Consider it done,
KTy
Main scooter: PX200, VNB177, T5, 150GS, V5A,
Another piece of advice; when you mount a Spark Magnifier (SM :) ), it is a good idea to change the spark plug, if it is in its end-of-life the SM could finish it faster :)
As for dyno, the guys on the GSF already did some, but it is worth mentioning that the SM usually brings a better "feeling", engine is more "round"; so don't expect more than ~5% power increase (some saw ~10% on some RPM range), but for sure a smoother curve.
Furthermore, you should dyno from very low-RPM if possible because it is more "visible" between idle and mid-rpm...
Cheers,
KTy
- www.kytronik.com
- My forum: scootentole.org
- French Racing series: challenge.scootentole.org - ESC compatible !
Special X
Emporers new clothes?
Only a back to back dyno run will tell. My money is on no discernable difference.
Special X wrote:Emporers new clothes?
What if there's no visible difference, but it feels better? :lol:
    Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
