LTH Europa 225 kit.
ArKaTxU
What do you think about this component mixture?
http://www.lambretta-teile.de/Cylinder- ... -Lambretta
What do you think about port timings?
130°/182°
Does it worth the money?
Thanks.
chris2470
Looks a good bit of kit to me, price quite reasonable considering all the piece parts.
It would benefit even more with some boost ports cut into the liner feed form the inlet then it would be almost perfect.
Best Regards
So.........a reedvalve 225 kit, complete with cylinder head, reedvalve inlet manifold and reedvalve piston with 1mm rings.....using 130 trans and 180 exhaust???
Why not just buy a TS1............you then get nicasil lining too????
giankx
I'll go directly to a TS1......
chris2470
Where can you get a complete new TS1 kit for what equates to 385.00 GBP these days.
Best Regards
pasner
chris2470 wrote:Where can you get a complete new TS1 kit for what equates to 385.00 GBP these days.
+1
hobospeed
scootercenter.com - 418.21 £ incl. VAT
http://www.scooter-center.com/scoweb/pa ... egory2=CAT
pretty close and I know which one I would rather have....
pasner
Its not a complete kit, you need to add a cylinder head :?
Aren't they £395 from AF??
CPH Lambretta
Main scooter: DL 150 1970
Scooter Center have 10% off everything at the moment (because germany are doing so well in the world cup)
Slow is the new fast!
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Semrush [Bot] and 10 guests
