playing around with a TV175S3 barrel
The exhaust port measures 37.0 mm from the top of the barrel to the upper edge of the port.
The lower edge of the port is 62mm from the top
The width is 42.6mm (as a chord- i.e. across the piston, not around its circumfrence)
Too big? Will be running on a 22mm carb and 42mm clubman?
Any thoughts Gents?
Chris
TV175 exhaust port- a port too far?
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
Scootering since 1968.
I make it close to 68% exhaust port width. You would need wire rings to span the gapbristolmod wrote:playing around with a TV175S3 barrel
Any thoughts Gents?
Chris
On a 58mm stroke crank with a deck height clearance of 1mm at TDC it would give an exhaust timing around 170 degrees. Which I think is ok for a 175.
But at BDC there will be a piston to port clearance of approximately 3mm this may cause extra heat at the piston crown at this point, which is not really a good thing
