engine cowl cover bolt
druist
is the imola cyl head the same as normal when it comes to the stubby bolt attaching the cover to the cyl? I just changed to the jl3 and for some odd reason the bolt i thought it was doesnt fit, its too thin. I cannot see due to the shape of the exhaust, even with a mirror - it may have got mixed up with others which i know are longer - have tried all except one which i know it isnt and that seems too fat but feels like its biting. I am loathed to take all off to see.
Can anyone tell me the depth and width of the main stubby bolt please and if the imola differs which i cant think it does. :o
druist wrote:is the imola cyl head the same as normal when it comes to the stubby bolt attaching the cover to the cyl? I just changed to the jl3 and for some odd reason the bolt i thought it was doesnt fit, its too thin. I cannot see due to the shape of the exhaust, even with a mirror - it may have got mixed up with others which i know are longer - have tried all except one which i know it isnt and that seems too fat but feels like its biting. I am loathed to take all off to see.
M8 x 16mm, it fits the elongated nut on one of the cylinder studs so it doesn't matter which engine or kit you use as they all use the same cylinder studs.
carlos fandango
barrel studs are m8 (13mm spanner)so the long nut and bolt are also m8 same as exhaust studs. It may be the exhaust stub pushing the cowl out of position.
druist
^^that seems likely as i have always it in the past, its the length that bothered me, i didnt want a rattler thanks
druist
thanks guys sorted just the bottoming out was a tad worrying on a bloody expensive kit, but also good. jl3 on and sounds great. Spin tomorrow :D
dirtyhandslopez
I am partial to the 14mm nuts myself. More threads available to bite on, better spread of the torque. As someone else said in a different thread, discussion availble on this? Of course , it's the washers that apply the load...but?
That's not going anywhere...
