Unable to Centralize Front Wheel
chisel
you need to use a lambretta std disc brake wheel spindle and get the caliper mounting plate rebated for this so you don't need to use any nut at all on that side,this will sort the job
Bilko
Main scooter: LI150
Thanks.
This plate is on the way so I just need a spindle.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Spindle ordered!
Thanks for the help.
Bilko's Oily Blog
Bilko wrote:
chisel wrote:post a photo of the righthand side of the wheel/caliper mount so as i can see which spindle you have,i should be able to let you know what to do then.Martin
Is this ok?
The existing spindle / axle may be ok with the thin nut removed as long as it has the shoulder to sit inside the rebated hole.
Early Sterling ones used a Lamby type drum spindle without the shoulder, Lamby disc spindles have the shoulder, I think Sterling and certainly scootRS now only use Lamby type disc spindles.
Disc type spindle..... http://www.scooterrestorations.com/lamb ... rake-axle/
drum type spindle.... http://www.scooterrestorations.com/lamb ... rum-brake/
Bilko wrote:Thanks.
It's in the post ;)
With this, and the spindle, you should be sorted
Bilko
Main scooter: LI150
Thanks a lot Mike.
Bilko's Oily Blog
Bilko
Main scooter: LI150
New bits helped a wee bit, but it ended up 20mm one side 35mm the other. I don't know what else can be done.
Bilko's Oily Blog
What's the distance between the links at the spindle without the wheel fitted?
Bilko
Main scooter: LI150
136mm mike
Bilko's Oily Blog
Hmmm, mine's 140mm but that still won't make it central. You may have to live with it or check your links and forks... or the hub's a duff 'un :-(
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
