Stop light keeps blowing
bristolmod
Mates SX150
12v electronic kit fitted. Bike runs fine and all lights and horn work well
EXCEPT the stop light part of the rear bulb which keeps blowing (no problems with the tail light part or indeed any other bulbs)
Correct 12v 21/5Watt bulb fitted
Any ideas Oh learned Electrical Ones??
Scootering since 1968.
thackers
I had a simillar prob after checking the earths i had a good look at the bulb holder (viet :oops: ) the bottom sprung loaded part with the contacts had twisted when i put a new bulb in and wasn't touching the end of the bulb tight enough plus it was a little slack in the metal socket where the bulb slides into. After a good while of fettling it work bang on. Might be worth a look :?
I agree with Thackers, it could be an intermittant contact, it would also be worth checking the brake light switch. Also, if it is a battery model then the stop light is fed off the DC circuit, have you checked the voltage across the battery at high revs, it shouldn't be much more than 14 volts max.
bristolmod
thanks for the ideas so far- no its a non battery type.
I'll check out the bulb terminals etc next week end
bristolmod
I'll try those tips over the weekend lads........
Just one thing, the filament is actually blowing rather than simply not working which indicates, to an electrical numpty like me, that the voltage is too high- is this possible as all the other filaments are OK?
Any thoughts welcome please Gents
firekdp
If no other lamp is blowing, then it cannot be that the voltage is too high, so can only be down to a poor connection somewhere in it's circuit. Poor connections can cause the lamp to blow.
