Ts1 idling speed
mickeyb
Hi folks....when i take my Ts1 out for a spin and after the engine gets warm the engine seems to be running a bit high when you stop at lights etc....tried the air mixture screw but no joy
Tmx 35 Mikuni
main 350
needle 57 2nd clip down
20 slide
4-1 mix
Thanks
Jazzy
first thoughts air leak, check hoses.
Knowledge
Yup, classic air leak symptoms. Split inlet manifold rubber? Gasket leaks?
Martin
J1MS
had to fix two scoots with a similar problem, One had a helicoil fitted to one of the two exhaust studs on the side case, (the ones that hold the main body of the exhaust on) but it had been drilled too deep and gone into the crank case primary chamber. then when the Engine was built up it sucked in air. the second was a ported casing where the mag side transfere had been left very thin, which then cracked down its length, letting air in (more so when it was hot) as the heat expanded the alloy opening up the cracked transfere, just though this might help in your Quest for a smooth tick over. All the best 8-) 8-)
camel
when you say a 20 slide,did you mean pilot jet?i run a 22.5 in mine,maybe you could try that first
    Users browsing this forum: Google [Bot] and 7 guests
