Delly VHSH SET UP
Spursy
Main scooter: Series 2 Bgm Race-Tour
Been try a vhsh 30mm carb on me scoot , could not find any links to any set up for a 175cc and noticed a few other peeps been having probs with set up info , so i thought these links i found may be of help ,,, even if some are for go carts carb setting up is the same principle :roll:
http://www.conerel.com/Portals/0/Pdf%20 ... Manual.pdf
http://www.conerel.com/Portals/0/Pdf%20 ... ircuit.pdf
http://www.dellorto.com/editor/uploads/ ... tlevel.pdf
http://www.conerel.com/Portals/0/Pdf%20 ... ogress.pdf
http://www.conerel.com/Portals/0/Pdf%20 ... irflow.pdf
http://ekmpowershop2.com/ekmps/shops/re ... -469-p.asp
Spursy
mawso
What set up did you go with in the end for the 175 with this carb?
I have one jetted for an Imola and will use it on Stage 5 Suzuki 190...just wanted to see what your set up was to see the degree of difference between Imola set up.
Cheers Stu
Spursy
took 175 kit off and put a 190 kit on mate ,, could not get the mid range set up correctly ,, so went back to 30 phb ,,,,,
    Users browsing this forum: No registered users and 49 guests
