Speedo Drive Replacement
Bilko
Main scooter: LI150
I'm about to replace the plastic drive inside the front hub with a metal one.
How do I remove the old one?
Bilko's Oily Blog
You need to grind it flat on the side and when thin enough it will crack. Page 157 in the bible ;-)
Bilko
Main scooter: LI150
f@@k. Forgive me, I hand the bible in my hand too.
Thanks SS
Bilko's Oily Blog
I actually changed one pretty easy recently with a plumbers adjustable wrench..
It's all ok until you come to fit the new one and it's too big!
Bilko
Main scooter: LI150
The new one needed fitting with a drift.
Bilko's Oily Blog
