LI steel fork spring top hats - is there a bush, too?
dansuper
Main scooter: 1963 LI 185
Probably a dumb question, but:
I'm just about to rebuild my forks (early LI series 3). I have steel top hats, but can't remember if there is meant to be a bushin the top hat. Or does the spring just go straight in?
Thanks,
Dan
Daggs
Don't know quite what you mean by 'stopper' The steel top hats have a 'plastic' bush that the rod passes through.
spring goes straight in the stopper tapers this is the spring stop ,the rods carry on through and into a small tube on the top
dansuper
shocky wrote:this bit usually in metal
http://www.scooterrestorations.com/lamb ... -li-tv-sx/
Thanks Shocky - yes, mine are the original steel versions of these. What I wasn't sure about was whether there was also meant to be a plastic bush within the steel stopper, as this doesn't seem to be clear.
Daggs' post indicates that there is also meant to be a bush - but I've just found a diagram that shows that there isn't...?
dansuper
Hmmmmm, just had a closer look at mine, and pulled out the remnants of an internal plastic bush that fits into the steel top hat. Double-checked 'Sticky's' and it confirms that series 2 and early series 3 were like this.
Don't think I've seen these bushes before - can i just upgrade to the GP type nylon ones, and leave out the top hats?
Daggs
Upgrade to the type shown in the Scoot.Rest. link.
Robi D
My ser. 1 steel tophats have a nylon like bush in them. But you can just upgrade to the new style. Don't know where you'd ever get a new bush at!
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 23 guests
