modifying fast flow fuel tap
fred
just tried a new fast flow tap,that was advertized as able to flow a pint in 47 secs. actually a pint in 1 min 10secs.
do you have to drill the 3 holes inside the tap,as well as the reserve,and on holes?
rps123
Who sells the fastest flowing fuel taps on the market, i too bought one advertised as a pint in 47secs and it was well over a minute with no filter on.
most people dont understand how a fast flow or original tap works imo people think that when the reserve is on fuel is flowing through both the normal hole and the reserve hole it is not as when you rotate the tap to the reserve position it closes of the normal hole and allows fuel to flow from the reserve only, TAFFSPEED fast flow taps are modded inside so that both holes flow fuel .....so i would say the taffspeed ones are the fastest
also the float needle is the limiting factor re fuel flow i doubt any will flow as fast as the tap
