jumping out of gear
sydduckett
My scoot is jumping out of gear quite regularly and its proving to be a right pain. Tends to do it more when im giving it some and happens between 2nd and 3rd and 3rd and 4th. Im thinking its the gear selector being worn or perhaps the spring?
Anyone have any suggestions before I open her up, also best place to get a good gear selector if thats the culprit.
Ta
Sefton
goffy
I had problems with gear jumping, thought same as you regarding the corse.
someone suggested changing the cables as a starting point ( and cheapest) as one might be frayed or snagging.
My gear selecting is now spot on ;)
worth a try for a few quid!
heliscoot
Playstation gamer tag: heliscoot
you havent got the cable rubber gaitors on have you?
is it still on the std indian selector spring ?
sydduckett
No gaitors, ill go over the cables again but i think there okay. Clutch has now gone on the car..never rains.. :(
onefortheroad
Main scooter: Li125 series 2
I had the same happening to me- tried to suss out which way it was popping (up or down) then tightened one cable up. Seems fine now
Fireman Ash
Gear cables too tight??
dirtyhandslopez
What make of Lammy? On some Serveta's the gear rod (from gear arm to inside case), the teeth are off and it'll always jump gear. Swop with Italian.
That's not going anywhere...
sydduckett
Italian series 3, have looked at the cables and seem fine but one is a bit frayed so will change all the cables and see if bthat makes any diff, before wipping the case off...
dirtyhandslopez
Shaft loose in the brass bush?
