Green
mikeallen
Xbox live gamer tag: junkyevenflow69
No nothing to do with the England goalkeeper :bouncyeng: But the colour of my spark plug at the porcelain & the electrode :?
Been keeping an eye on the plug colour since fitting the Breath sweet filter & JL3 just to be on the safe side & not running too lean but I am miffed at the greenish colour of the plug.
Have done choke tests at 1/4, 1/2, 3/4 & full throttle & nowhere does it indicate that I am lean. However after doing plug chops & checking the plug after a good run out I am a bit baffled at the Green colour of the plug porcelain & the electrode In fact one side of the plug is a dark grey & the other side is a greenish colour :?
Hope you can make it out from the pic
The plug is an NGK B8ES with a bit of town & fast 'A' road riding.
Using same crappy unleaded fuel from Morrisons & no change to my Rock oil two stroke mixed at 4%
Is it a case of green oxide indicates overheating the plug :?:
Rapido 225, JL3, 28phbh on Breath sweet filter, AV264 x13 @p2, 50 pilot, 120 main, 40 slide, 60 choke.
Don't want to cause damage to my engine so any advice much appreciated :)
minotaur
this is a quote that i found on a 2 stroke site
Excessive green oxide indicates overheating the plug. a lot of spark-plug electrodes have an alloy composition that will oxidize green when subjected to high temperatures. The nickel oxide on the center wire and strap would show up first at the tip of the electrode (the hottest part) and progress from there. Some would suggest going to a colder plug. I suppose a lean condition could cause this as well.
dirtyhandslopez
Never seen green. See red occasionally and put that down to ethanol in the fuel. Very interested in this one.
That's not going anywhere...
LeeLee
Looking at the rest of the plug, I would say that the mixture could be a bit rich.(Depending on throttle position of course).. I would have thought this would be the signs of the plug beginning to break down. I would try another plug bruv..!
mikeallen
Bit of an update.
Changed plug to a B7 & gave it a good run out at all throttle positions including some 60mph long cruising. Basically the same good run I did this morning with the B8.
Did plug chops & also checked plug when I got back all reading a nice light tan colour as it should be :D
Could it be a case of the B8 breaking down :?
I was just a bit puzzled as all the plug colour charts on tinternet don't seem to mention a green coloured plug :?
cheers
mike
    Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
