CamLam Rear Exit Fast Fuel
paulmgreen
Just fitted one... and .... erm...... either I'm being dumb or theres something amiss!
Tap is fitted- but its like the mechanism is out by 90 degrees!
Looking at the tap its like it's turned anti clockwise - Off is at 9 o'clock with teh tap facing inwards, On is straight up, Reserve is the normal on position... and thats it!
Has anyone else fitted one?
www.JPPLambretta.co.uk
Dazza
Yes and it's fine, you been on the vino?
Dazza
Don't you just need to undo the two screws and rotate the mechanism 180 degrees clockwise?
paulmgreen
hhhmmm don't think so dazza.... the fuel lever is 90 degrees out?
maybe if I drank some vino it would be ok lol
Are you using a brass joint between the tap and lever?
http://lambrettaspares.com/spareparts/f ... l0311.html
paulmgreen wrote:Has anyone else fitted one?
Yes I have fitted one Paul and believe Eden also..mines TBH is as it should be and cant remember doing anything different from the norm..
paulmgreen
soulsurfer wrote:Are you using a brass joint between the tap and lever?
Yep! of course..
Weird ain't it!
Sure is. Mine fitted okay too. I guess yours has been assembled wrong ;-? Maybe you can remove the joint or add another, or send the bloody thing back, at their cost of course ;-)
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
