Serveta - battery bypass?
Funkspeed
Main scooter: Rally 200
Hi all,
Just a thought (as it appears that the battery on my Serveta has died)......is there really any need to run a battery and can this be easily by-passed. My Rally 200 used to have a battery but no longer runs one so I'm guessing its doable but is it easy enough to sort?
On the Serveta it seems that the lights & indicators worked off the battery alone and it wasn't being recharged.
Cheers
Rob
Stampede
Main scooter: SX200
Running without a battery will kill your stator & coil, both are hard to find for the motoplat ignition these days!
Simply fit a battery and all will work fine! ;-)
Funkspeed
Stampede wrote:Running without a battery will kill your stator & coil, both are hard to find for the motoplat ignition these days!
Cheers....looks like the wife is going shopping in her luch hour tomorrow!! :D
Funkspeed
Actually now suspect my charger is knackered!! Great!
firekdp
If it's a 6v system then its an easy conversion to 12v AC using a vespa reg (although it may struggle to power indicators as well as lights), but try your system with a good battery before you ditch the original reg/rec.
Funkspeed
It's already 12V but need to check my charger and battery I guess. Always summat!!
    Users browsing this forum: Ahrefs [Bot] and 7 guests
