TV rod length- any theories?
bristolmod
Anyone hazard a guese as to why Innocenti made the TV175 with an odd length con rod?
IMO its the best bike they ever produced and scores over its big brother on handling and smoothness. But why the odd length rod?
Any ideas?
Scootering since 1968.
simon k
58mm stroke 116 rod. the rod exactly twice the length of stroke, a "square" crank for smooth running??
J1MS
simon k wrote:58mm stroke 116 rod. the rod exactly twice the length of stroke, a "square" crank for smooth running??
Is right......... 2 to 1 rod to stroke ratio..........
Knowledge
The 2:1 ratio is common amongst tune stroke engines.
The better question would be why did Innocenti chose 107mm for the more common Li/SX range of scooters. In fact, another question would be why choose sizes that no one else uses, hence con-rod swap-out tend to use 110, 115 or 120mm rods.
Martin
its really quite a mystery.............
that only innocenti themselves could explain...................
:lol:
tony
Main scooter: 90ss
Or maybe a technical answer! ;)
This one is gonna run and run. :P
Lamaddict
I always thought/read somewhere that the common crank in the S1-3 had roots in design with the C, D ranges etc and that could be the reason for the 107 conrod length. :?
red ghost
Main scooter: lambretta gp150
At a guess Martin,you answered your own question ;)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
